Just Installed #10 Plate. What A Waste...
Old Aug 27, 2007 | 08:09 PM
erik s's Avatar
Default Just Installed #10 Plate. What A Waste...
What a waste....of perfectly good tires and fuel. I was very impressed with how how much power I gained. What concerned my was how high my boost and EGT's got. Prior to the install, i maxed out at around 18-20 PSI boost and 1100-1200 degrees pre-turbo. Now I am reaching 26-28 PSI Boost and peg 1400-1500 Degrees.
How much of each is too much.
I set the plate 1/16 back from full forward and slid the AFC full forward. Is this a reaonable set up.
I have a NV4500 with a GV splitter. 1st and 2nd are still unimpressive with little to no smoke. 3rd-4th-5th smoke moderately and pull very hard.
3K GSK are to be installed tomorrow.
Old Aug 27, 2007 | 09:47 PM
Benjamin's Avatar
Bombardier
you'll prolly want to move it back to the stock position once you get the 3GSK in place..... it'll get HOT quick......
Old Aug 27, 2007 | 10:33 PM
DBogo's Avatar
hang on a sec is this on a 215 truck? if not them numbers seem kinda off, if you got the stock wastegate setup without a boost elbow you might be on, do you have an intake and exhaust if so them egts seem kinda high unless its a 215 pump. i have to work to hit 1200-1300, your egts are pretty warm, if you dont have an intake and exhaust get that and also get a adjustable boost elbow that will increace your boost a little and reduce your egts due to more air, with my wastegate unhooked i could hit 40 pounds like nothin but thats way way too much, thats too much on the turbo and on the headgasket so i put a boost elbow on to control it
Old Aug 28, 2007 | 05:48 PM
EMD567's Avatar
Yeah I was gonna say, I get up to 1200* empty up hill wide open and I got 370's in my truck and an 8 plate in about the same spot you have. The boost numbers sound a little low, check your turbo for the vacuum line going to it and yank it off of there, and stick a bolt in the end. That will help until you pick up a boost elbow. Its doing no good
I can hardly even peg mine with a trailer out back.
Old Aug 28, 2007 | 07:37 PM
erik s's Avatar
i did get a boost elbow with the fuel plate. I haven't adjusted the allen head at the back at all though. Should I???
I just a few minutes ago finished installing a MBRP 4" exhaust. I haven't test driven it yet to see if it made a difference in EGT's, at the moment I'm just to filthy to get in the truck.
I have the Low output pump, i think its a 180HP, because Its a California edition with all the smog junk on it. I think the restrictive cat added to the EGT's
What would a normal boost be at with this set up. I thought 26-28 psi was high
Old Aug 28, 2007 | 11:58 PM
DBogo's Avatar
i would set it for like 32 or there abouts maybe even 35, but those egts seem really high for a 180 truck, the exhaust should help some, also get an intake
Old Aug 29, 2007 | 10:49 AM
Johnny Cetane's Avatar
yeah an intake will greatly help you out. or even just a quality BHAF with a heatshield will do wonders and carry you up to about 400 hp.
vin_diesel
Mar 1, 2016 01:43 PM
Flikkie2001
Jun 26, 2015 12:53 AM
SMatyac
Nov 15, 2014 07:35 PM
JustAnother_cummins_guy
Nov 10, 2014 09:44 PM
12v_freak
5.9L 12V Performance
9
Oct 10, 2014 02:33 PM
