Injectors, fuel plate question
Old Feb 16, 2010 | 07:21 AM
Cnallick's Avatar
Default Injectors, fuel plate question
Guys,
I have a 97 with the P7100 pump bone stock truck. I went to Pensacola Injector yesterday and priced a 100HP set of injectors and they are $199. Not bad
Question is if I add the injectors should I change the fuel plate Adjust the afc, and pump? Also going to add the boost elbow. I see different write ups on this stuff but not all together like this. Thanks for the help! Before I get flamed I did read on here the little role play the fuel plate has in the performance, It is just included in one of the kits I was looking at!
Old Feb 16, 2010 | 12:42 PM
wes-cummins's Avatar
just slide the plat forward, and tune the afc, you can always take a grinder after your fuel plate
Old Feb 16, 2010 | 06:19 PM
Cnallick's Avatar
Should I grind the plate first before sliding the plate, and afc adj.
Old Feb 17, 2010 | 08:06 AM
PhilipR's Avatar
Do you have gauges?
Old Feb 17, 2010 | 08:09 AM
Cnallick's Avatar
Originally Posted by PhilipR
Do you have gauges?
Looking online now!
Old Feb 17, 2010 | 08:11 AM
PhilipR's Avatar
Send a PM to Ken's Performance....he's a sponsor here....I got mine from him and Kenny has some of the best Customer Service out there.
Old Feb 17, 2010 | 08:38 AM
9412Valve's Avatar
Get you a boost gauge and EGT to watch those temps.. As for grinding your plate.. you may not end up with a good curve - sometimes it's best to buy one if you get a good deal on it.. that way you can always change the plate out.. if ya screw up the grinding job, well you're stuck with that plate. Anyway, the 100hp injectors, #0 plate full forward with 191 DV's.. My buddy's 97 was running HOT (boost elbow too). Smoked like crazy, and was pretty quick.. but he found out he needed a turbo.. he was peggin out the pyro easily with that setup. Plan out what you want your HP goals to be, then start finding out what you're gonna need to get there. For example, if you add too much HP, you're gonna need an upgraded clutch (double disk at least), or if you've got an auto some other upgrades to it. Just somethin to think about..
Old Feb 17, 2010 | 11:57 AM
Cnallick's Avatar
I did search with no results, but any of you used the Power kit from TST with the #10 fuel plate? It claims 33HP and 750 LB torque. Is it worth the buck, and have any of you seen these type of results.
Old Feb 23, 2010 | 12:26 PM
YOUNG GUNS's Avatar
forget the penscola injectors.... just remember you get what you pay for.....
Old Feb 23, 2010 | 01:57 PM
xzaq103's Avatar
FormerVendor
215 or 180 truck?
I would also stay way from Pensacola... As for a fuel plate just cut your own. A plate alone will slip the stock clutch/TC.
