edge drag comp and 65 hp injectors?
I was wondering if 65 hp injectors and a drag comp would make good power? right now i just have 65 hp injectors and im now looking for a drag comp and i was wondering if it would make good power? Thank You.
what elese do you have done to the truck you need to fill out your sig the guys on here can help you better if they new everything about your truck.
but yes i think that it would make good power but you must have gauges and lift pump and possible trans work valve boddy and torq converter work done at least
i think the ddrp might be a little small for that setup but not sure what the output is. the raptor 150 is a good cheaper pump. i got the ard. with the rv275 and they suck the fuel presser down a little bit.
but put that extra power comp edge on with the 65 injectoers and you will go in to the danger zone under 8 psi. raptor 150 it would be more safer than the ddrp, can gripe or brag never run one but heard it was more for stock to mild.
