Need Help TRAC BAR
Old Feb 15, 2010 | 07:17 PM
NCFPD's Avatar
Default Need Help TRAC BAR
ok i went to replace my trac bar and i cant get the end off that connects to the frame it is like a ball joint i have a ball joint puller the fork kind and i have beat on it with a flat head axe from the fire house for like 3 hours and it still wont pop free how do i get it off.
Old Feb 15, 2010 | 07:31 PM
turbo20psi's Avatar
Put some heat on it .I have the reverse problem I hit mine and it fell into pieces.Im assuming you are putting on a 3 gen trac bar.
Old Feb 16, 2010 | 07:09 AM
NCFPD's Avatar
no the new bar is like the stock one but i got a life time warrenty on it
bumbany body
Old Feb 16, 2010 | 09:37 AM
Diesel Nut's Avatar
What we do is take the nut and such loose and use an air hammer to impact the end of the ball joint and it usually pops loose. A little heat on the frame mount should loosen it as well. My guess is you werent able to get a solid hit on the end. Don't round it over too much or it will fight you out all the way.
Old Feb 16, 2010 | 10:11 AM
96blackcloud's Avatar
had the same problem beat the **** out of the side of it like you would with a ball joint, use PB blaster, i used a fork and got it to pop but all else fails use a bigger hammer for more *** or resort to the blue wrench aka torch
Old Feb 16, 2010 | 10:15 AM
94cummins12v's Avatar
i never even bothered with a hammer to much work i just used a heav dutuy 2 jaw gear puller and poped out evrytime
Old Feb 16, 2010 | 10:18 AM
AndyMan's Avatar
Yah. Jaw-puller works good, and air-hammer works good. heat never hurts!!! It can be a bear to get loose, but it'll eventually let go.
I had a couple of those lifetime warranty bars.... The warranty is great, but you still have to take it off. I finally gave in and bought a DT Trackbar. Money well spent. I've finally been able to forget about the trackbar.
Old Feb 16, 2010 | 07:08 PM
2500superram's Avatar
get yourself a pickle fork.
carid
Diesel Bombers Sponsors
Sep 2, 2015 06:56 AM
CGwill
Jan 26, 2015 02:10 AM
mark402001
Tire, Wheel & Suspension
Jan 18, 2015 03:17 PM
12vbomber
Nov 11, 2014 10:58 AM
motormayhem
Nov 1, 2014 01:24 PM
