94 47rh to nv4500 swap help!!!!!!!
Old Feb 15, 2010 | 06:50 PM
Nick01psd's Avatar
Default 94 47rh to nv4500 swap help!!!!!!!
I have a 94 2wd with the 47rh and im in the process of swapping in a nv4500 and got some questions..
What trans mount should i use for the nv4500...i heard a stock GM turbo 350/400 mount????? will that bolt right up to the factory crossmember and nv4500??????
what is everyone doing with the harness and hooking up the clutch switch????
I hope some of you have the answers for me...im starting to question myself if i should have even started this swap... Thank you!!!
Old Feb 15, 2010 | 08:49 PM
dshane62's Avatar
i did my 95 from auto to getrag you should be able to use your crossmember and
i used the tranny mount from the auto but i also used the front driveshaft from a 93 d350
dually and had to cut about 1.5" off the spline end. as far as the clutch switch i think it was a green wire i had to jump power to the switch and ground the other side of switch switch is on master cyl hanging the peddles was easy the part you run the shaft thru is already there . i think getrag &nv4500 are the same except getrag weighs a ton so there is a switch on top of tranny its backup lites good luck i guess some trucks have a square plate where the shifter goes mine did not
Jonrarick
Oct 25, 2016 01:32 PM
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
Ryans71
Dec 24, 2014 08:47 AM
CumminsMan2.0
Dec 11, 2014 04:57 AM
Jgloveracob
Nov 16, 2014 07:27 AM
