oil pan leak
You have to pull the fan, then take the motor mounts loose. Rig a jack to catch the harmonic balancer or use an engine hoist and lift the motor up out of the mounts, pivoting on the transmission mount. You can then drop the pan and reach in and drop the oil pick up tube, then remove both out the back together. Get a new gasket for the pickup tube too.
Put a small dab of sealant where the front and rear covers meet the block.
Trq everything to 18ft lbs.
pro graphic solutions
Feb 10, 2015 03:48 PM
