waste gate
Old Feb 14, 2010 | 09:32 PM
hulse09's Avatar
Default waste gate
is it ok to plug off the hose that gose to the wast gate?? build more boost?? some guy told me to do that. dk if it will hurt my truck any
Old Feb 14, 2010 | 10:03 PM
mainman300's Avatar
running lean will cause heat. watch egt's
Old Feb 14, 2010 | 10:59 PM
Use an ajustable boost elbow. The wastegate protects your turbo.
Old Feb 15, 2010 | 07:34 AM
Gear Poet's Avatar
Or you could do what I do with no wastegate at all - which is watch my boost and EGT gauges very carefully. But I'd recommend an adjustable boost elbow, too.
Old Feb 16, 2010 | 07:17 AM
sledwrecker's Avatar
These arent snowmobile engines, Lean would indicate too much air and not enough fuel. On the contrary......Diesels heat from too much fuel and not enough air.
Old Feb 16, 2010 | 08:00 AM
mainman300's Avatar
did it on my friends 12v with a hx35/40 hyb, egt were 1200-1300 at manifold, added a little more fuel and cooled it right down
Old Feb 16, 2010 | 09:14 AM
crazycooter's Avatar
too rich or too lean will build too much heat. This is true no matter what sort of engine or which sort of fuel. There is always an acceptable range for every setup, it is usually just figuring out the right range.
Old Feb 16, 2010 | 09:31 AM
Diesel Nut's Avatar
You can only have as much air as combustion can drive the charger. If you are short on fuel the charger can not really overbuild boost in a properly matched set up. Now, you can have excessive EGTs from running a turbo outside of its map, or efficiency zone, and the high EGTs are from the excessively hot intake charge at the engine.
The point of the wastegate is to bypass the turbine to control turbine speed and thus, boost pressure, so the charge doesn't overspeed or create too much heat. Overspeeding the charger can cause high EGTs, excessive turbo bearing wear, and ultimately, turbo failure. On an HX 35 we like to see about 36lbs of boost. anything more than that it makes more heat than the intercooler can effectively cope with and you gain nothing. If you need more air than that you need a bigger charger. Use the adjustable boost elbow.
Old Feb 16, 2010 | 12:36 PM
mainman300's Avatar
vin_diesel
Mar 1, 2016 01:43 PM
six speed
Sep 14, 2015 09:19 PM
timmyd
Jun 8, 2015 11:35 PM
carid
Diesel Bombers Sponsors
Jan 19, 2015 08:30 AM
