air to water intercooler
Old Aug 26, 2007 | 08:40 PM
diesel junkie's Avatar
Default air to water intercooler
ant info? dyno numbers? where can a fella buy one? or can the stock be made into one for a cheap bomb?
Old Aug 27, 2007 | 12:14 AM
rufushusky's Avatar
I saw in one of the diesel magazines that the guy from ATS had an air to water intercooler I guess you could give them a call.
Old Aug 27, 2007 | 09:27 AM
Begle1's Avatar
Air to water intercoolers are small boxy units; the genuine Cummins ones actually mount on top of the engine and require different injector lines. (At least the ones they made for the older engines do.) There are aftermarket universal ones that can be plumbed in anywhere along the air intake, though.
The primary advantage is that they are a more compact unit, they don't leak as much boost, the reservoir can be filled full of ice in a quarter-mile or 300 ft situation and the radiator can be mounted as far from the engine as you want it.
The downside is that the system is more complex; it requires a pump to circulate water through a radiator. And it won't pull heat out of the intake air any faster than a standard intercooler, and if the radiator you are using is smaller than the intercooler you started out with then you'll see a rise in temperatures after a while.
Cougdiesel
Feb 2, 2016 10:17 AM
carid
Diesel Bombers Sponsors
May 27, 2015 07:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
veggyoilkid
Nov 10, 2014 12:39 PM
