how much smoke is a bad thing?
Old Feb 14, 2010 | 12:47 PM
crazycooter's Avatar
Default how much smoke is a bad thing?
I just put in some + 50hp injectors from pensacola diesel and now I blow thick black smoke at anything more than 1/4 throttle. also when I get to 70mph, and start to get past 2000rpm, it starts to cut out like it not getting fuel or something. I have a new vp44, and an airdog 100 with clean filters and a dummy light that comes on at under 10 psi(its the only pressure switch I could find that was close to what I needed). Also, I was really hoping that my new injectors would get me past that 12.8 mpg that I have been getting since even before the ip was changed. Any suggestions?
Old Feb 14, 2010 | 01:25 PM
RAW's Avatar
RAW
How about the filter on the engine block, or is it by passed? Engine air filter clean? Try running without the filter, but only for a short stint to see if that is the problem.
No programmer of any type?
I put +50 HP nozzles into my '01 and everything became better. I have no smoke on stock mode.
Old Feb 14, 2010 | 02:45 PM
Many people have been quite disappointed with Pensacola diesel products.
Old Feb 14, 2010 | 02:56 PM
Stock filter is non existant, I will try cleaning my air filter.
Old Feb 14, 2010 | 05:58 PM
Codgedodger's Avatar
FormerVendor
injectors from pensacola diesel are made purely from china...
Old Feb 14, 2010 | 06:03 PM
DixonPeer's Avatar
Oh boy!
Old Feb 14, 2010 | 07:18 PM
98dodgecummins's Avatar
i dont get it i have 65 hp injectors and my truck hardly smokes i dont get it?
Old Feb 14, 2010 | 11:01 PM
luke46's Avatar
I almost bought from them but I read lots of reviews just like yours so I got some EDMs from lukes diesel here for almost the same price and it barely smokes at all with lots of good power
Old Feb 15, 2010 | 08:30 AM
powerstroker52's Avatar
i have 100HP sticks in my truck and they run clear as he:: no problems at all even improved fuel millage so like stated above check the filters and stuff
thats good it shouldnt smoke unless you tap your pump with a good box like edge or quad. you dont want the truck to smoke stock with just bigger injectors
Last edited by powerstroker52; Feb 15, 2010 at 08:30 AM. Reason: Automerged Doublepost
Old Feb 15, 2010 | 09:09 AM
that is what I was thinking. I think I am going to make pensacola send me some different ones or my money back. I am not very happy with the current result. I had good luck with my psd injectors from them, and my vp44 works fine, so I thought, well... you know what I would have thought.
