Oil Pan Replacement
Old Feb 14, 2010 | 09:22 AM
Drothgeb's Avatar
Default Oil Pan Replacement
I need to replace my oil pan. It is possible to get it out by just raising the engine, or do I need to pull the trans? All the steering linkage is out and the axle housing is just hanging, so I have some wiggling room.
Old Feb 14, 2010 | 10:05 AM
9412Valve's Avatar
I'm not sure about not pulling the transmission, but you might just be able to do this - I'd try it anyway. Save you some time
Old Feb 14, 2010 | 10:17 AM
94 12valve's Avatar
There are only 2 motor mounts holding the motor in, you may have to take the trans crossmember bolts loose but it sounds like its worth a shot.
Old Feb 14, 2010 | 10:26 AM
R&RDiesel's Avatar
FormerVendor
I think if you lossen the tranny mount bolts and the motor mounts, raise the motor up a little bit, you should be able to get it out. It just really tight.
Old Feb 15, 2010 | 12:37 AM
jrad989's Avatar
undo motor mounts and raise the engine up exactly four inches. no more. make sure its secure.
Bighouse
Apr 9, 2015 06:51 PM
CRCSI
Mar 29, 2015 11:26 PM
98cummins
Jan 29, 2015 08:23 PM
BCOWANWHEELS
Wanted To Buy (WTB) - Used
Jan 7, 2015 03:42 PM
98cummins
Dec 9, 2014 10:14 PM
