turbo is froze up
Old Feb 14, 2010 | 07:37 AM
swamprat's Avatar
Default turbo is froze up
would the airflow restriction be enough to keep it from starting and to slow the starter
Old Feb 14, 2010 | 07:49 AM
94 12valve's Avatar
umm, when you say your turbo is froze up I'm assumeing it will not spin at all is that correct?
Your truck should start and run without a turbo. It just wont run very well.
make sure your shutdown soleinod is pulling up when your cranking and if your turbo is shot you will need a new one.
Old Feb 14, 2010 | 10:30 AM
R&RDiesel's Avatar
FormerVendor
Not to sure if it will start when a turbo is froze or not. Take the turbo off and try to start it. Like stated above, make sure you shut off solinoid is working properly.
Old Feb 14, 2010 | 10:39 AM
94 12valve's Avatar
I know it will start and run without a turbo and I don't think a froze turbo is enough of a restriction to keep it from starting. Could be wrong I've never had one lock up on the truck
Old Feb 14, 2010 | 11:09 AM
R&RDiesel's Avatar
FormerVendor
Thats what i said try and start it without the turbo, meaning if it starts without the turbo, then the locked up turbo was the problem, if it does not start, then he has a different problem.
Old Feb 14, 2010 | 12:35 PM
12valvetater's Avatar
My buddy had his charger lockup on him it started and ran just very badly.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
