EDGE Juice w/Attitude
OK... I have a drag comp box right now. Previous owner had a new VP44 put on in June of 09, so its not currently tapped and will not be til this June when the warranty is up. That being said I am considering the drag box and getting the Juice w/Attitude, mainly for the Attitudes multiple uses in monitoring. I see quite a few people are using the Juice and the drag/comp boxes. Jus looking for feedback pos/neg for i spend $700. Also what can u get out of a used drag box? Thanks ahead of time.
since you have the drag comp run it and run gauges. The boost is not accurate on the attitude, as I was running this on my 01 and put a manual boost gauge on and was making 10 psi over what the attitude said. reading your sig all you need is a fuel pressure gauge and your good to go. the comp and juice are supposed to be the same programming, but I think the comp works better.
Ram700
Jan 2, 2015 08:14 PM
somarillw
Dec 3, 2014 05:55 PM
just done it on my truck
and what a difference it made in low end power, now the turbo lights up quick and does its
