how much power
Old Feb 12, 2010 | 12:15 PM
motown's Avatar
Default how much power
i'm just wondering what the stock clutch can handle and what the best way to get the power would be
Old Feb 12, 2010 | 12:24 PM
Hightech_Redneck's Avatar
need some info on what ya got ...
Old Feb 12, 2010 | 01:07 PM
94 12valve's Avatar
it will handel whatever you throw at it ... till it slips, then it just keeps getting worse and worse.
On a more serious note mine held 379 rwhp then shortly after started to slip
Old Feb 12, 2010 | 04:10 PM
Hammer's Avatar
Its not the HP that kills the stock clutch,its torque.
Early in 99 when I first started woking on mine we did some tweaks and tunes to it and it laid down 340hp/1018 torque with a stock pump and injectors.That combo I drove for a few years but the quick spoolup and torque load slipped and glazed the clutch which was why I bought my first double disc.
Added HP is hard on the stock clutch but the added torque kills them.
Old Feb 12, 2010 | 05:44 PM
Shea@L&N Performance's Avatar
FormerVendor
Also depends on how you drive it. If you drive like a normal human being it might last a while, it might not, but if you romp on it a lot doing boosted launches and such it wont make it long at all.
Old Mar 1, 2010 | 09:25 PM
motown's Avatar
drive like a normal person noway i tow a good bit and the pedal hits the floor all the time
Old Mar 2, 2010 | 06:44 PM
megaram's Avatar
Cool Power
The #10 plate will slip a stock clutch
Old Mar 2, 2010 | 09:38 PM
R&RDiesel's Avatar
FormerVendor
You start tinkering with your pump or what not, and messing around with it on the road it will destroy a stock clutch over time, depends on the power level and how you drive it, will tell you how long it will last.
Old Mar 8, 2010 | 07:06 PM
motown's Avatar
I guess a clutch will be my first performance upgrade thanks for the info
May 10, 2015 10:57 PM
explorer197143
Dec 28, 2014 01:14 PM
