Hard Cold Start
Old Feb 11, 2010 | 02:04 PM
rsewell's Avatar
Default Hard Cold Start
have a 04 6.0 early engine, 161,000 miles, new fuel and oil filters, 15w40 oil, temp's in the 20's. start good with heater hooked up over nite. but then won't run godd until has ran for a few minutes, have done ficm resolder with readings of key at 36v, buzz at 48v, run at 47.4 volts with the pcm power on. old readings were key on 20v, buzz 48v, and run 33v, all this when engine was cold. without heater have to cycle key 6-7 times to start and no power and misses for the first 3 miles. has new injectors in 2,4,6,8. number 8 was replaced about 4, 000 miles ago for the second time, which ran about 4,000 miles. I would like to know the best way of checking th glow plugs and pcm.
Old Feb 11, 2010 | 03:06 PM
ArizonaRedneck's Avatar
read this and see if there is any info that will helphttps://www.dieselbombers.com/ford-p...n-t-start.html
Old Feb 11, 2010 | 03:15 PM
MUDSTROKIN''s Avatar
I don't see a?
Old Feb 11, 2010 | 03:22 PM
thanks mudstrokin sometimes that happens when you get older
Old Feb 11, 2010 | 03:59 PM
hahaha still no link redneck....
Old Feb 24, 2010 | 04:23 PM
rsewell's Avatar
THANKS TO SWAMPS AND WIEKIE THE RESISTER AND RESOLDER FIX. REPAIRED MY PROBLEMS OF HARD COLD START AND RUNNING BAD UNTIL WARM, EVEN TOOK AWAY MY BLUE SMOKE ON START UP. IF IT WAS NOT FOR THE ALTENATOR GOING SOUTH COULD HAVE FIXED FOR $5.00 SOLDER AND ALL.
94turbostroker
Feb 26, 2016 07:51 PM
Dcbb93
Nov 30, 2015 10:18 AM
Blanton
Apr 15, 2015 06:29 PM
dfish001
Mar 30, 2015 03:07 PM
custom7.3
Nov 23, 2014 10:44 PM
