236 code
Old Feb 11, 2010 | 03:03 AM
1longbed's Avatar
Default 236 code
I keep on getting a 236 code can't figure out what's the prob, I got a Banks Big Head actuator could this be it??
Old Feb 11, 2010 | 03:21 AM
coyropin's Avatar
you might need a boost fooler is what it sounds like
p0236 Turbocharger boost sensor A range / performance
Old Feb 11, 2010 | 09:52 PM
turbo20psi's Avatar
What kind of boost,are you reading at full throttle?P0236 Map Sensor Too High Too Long Wastegate problem or smoke switch left on meaning the ECU is seeing more boost then it knows what to do with.Boost fooler needed.
Old Feb 13, 2010 | 04:34 PM
cumminscrazy21's Avatar
p0236 is turbo boost sensor A circuit low which either means you need a boost fooler or if it just started happening then your MAP could be bad
Old Feb 15, 2010 | 10:36 AM
jkidd's Avatar
did you block off or modify the wastegate?
Old Feb 15, 2010 | 12:14 PM
dieseldocter16's Avatar
If your not running a chip that plugs into the map sensor you will probably a boost fooler to prevent the ecm from throwing an overboost code due to your modded wastegate.
dwmeehan
Sep 6, 2015 04:20 PM
Saams69
Jul 20, 2015 11:21 PM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Backhoeman
Jan 3, 2015 12:53 PM
