tranny question
Old Feb 10, 2010 | 07:43 PM
dodgeman129's Avatar
Default tranny question
i got a 95 auto 47rh tranny it blew up and i was wondering would a tranny out of a 94 with a v10 work and would it bolt right up i cant afford to rebuild the one i got or buy a good tranny but i ran into a good deal on a 94 v10 truck i need fix it so i can sell it
Old Feb 11, 2010 | 12:00 PM
wes-cummins's Avatar
ive been told they the same tranny, as long as the electronic are same on both trannys
Old Feb 11, 2010 | 07:22 PM
cummins95's Avatar
it should be the same tranny, but i think the torque converter should be quite a bit different. the diesel should have a considerably lower stall than the gasser.
Old Feb 11, 2010 | 07:33 PM
Hightech_Redneck's Avatar
you should be fine due to both having the 47rh trans.... you might have to change the vb due to the shift points on that V10 im not positive though....
Old Feb 12, 2010 | 07:15 AM
i can just take the valve body out of mine and my torque converter .thats if i didnt break both of them .cause i know something inside the trans broke. but the v10 truck only has 70,000 on it i can get it for 900 dollars for the whole truck, motor is blowed up and some of the body is shot typical dodge .
Old Feb 12, 2010 | 11:20 AM
get it then..... you can part that out and make some money
Lifted93cummins
May 31, 2015 02:16 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
wilki
Feb 12, 2015 09:04 AM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
Ol' RED!
Dec 11, 2014 10:00 AM
