Clunk
Old Feb 10, 2010 | 04:38 PM
RamHD's Avatar
Default Clunk
when im driving i let of the gas pedal and coast, i hear a clunking sound coming from the front drivers side, as the truck slows down the clunking noise slows down as i speed up the clunk speeds up and fades off a friend of mine told me maybe my u-joints are going bad, could my friend be right.
Old Feb 10, 2010 | 06:23 PM
dieseldocter16's Avatar
Check the u-joints.
Old Feb 10, 2010 | 06:40 PM
392hemix's Avatar
How many miles are on your truck? your friend is most likely correct. i would put your truck on a lift/jack stand and just rotate the tire back and forth, if you here the noise or see movement in that joint...bingo bango its the u-joint easy cheap fix if you do it right and keep the wheel bearin in one pice when you remove it! make sure that you buy the amaerican greaseable joints, they last much longer! unless you do alot of 4x4 launches buy the solid non greaseable ones, they will take a beating and wont be prone to snapping
Old Feb 11, 2010 | 07:21 AM
steved's Avatar
Check the lower shock bolts and the sway bar end links...
Old Feb 11, 2010 | 05:23 PM
RamHD's Avatar
There is 41,000 miles on the truck, thanks for the help.
Old Feb 11, 2010 | 08:34 PM
darkhorse06's Avatar
Check the ujoint in the axle. Easy fix. My truck has 136,000 on it and I've had to replace the drivers side three times... They're fairly inexpensive, $58.00 at o'Reillys. Finally said the hell with it and bought a new axle...
Old Feb 12, 2010 | 04:51 PM
RamHD's Avatar
had my mechanic check out my Ujoint to day the driver side is pretty much done for looks like going to be changing them out,,,,, mi may just do both of them for greaseable joints.
