Quick ? running AFC cover w/2 screws
So i was in the AFC today to check the measurements on my fuel plate before i grind another new one and as i was putting the AFC cover back on i dropped one of the screws and it disapeared into a black hole somewhere and cant be found, do yall think im good to drive on two screws about 14 miles to work tomarrow before grabbing new ones?
Also should i use the X system and put the 2 remaining diagonal from each other or on the same side of the cover?
no i saw it bounce off and head south towards the motor mount but it never came out the other side and i cant find it and neither can my maget stick
im feeling like i should be good to go cause i cant wiggle the cover at worse maybe have some fuel leakage..what do you think?
i only have two in mine..... its easier that way..... i havent had any leaks with it.... i use a larger head (10mm) on mine too so that all the bolt heads are the same..... most of the time i run two but i can run three at times.... i dont install the one by the injector lines..... IMO you'll be ok just make sure they are tight
ive had only 2 in it for a while, you need m6x 16, i think 1.00 pitch
had the same problem droped them some where and couldnt find them,... stupid little screws!
Last edited by wes-cummins; Feb 11, 2010 at 12:11 PM. Reason: Automerged Doublepost
I'm 22 and the same way. It took me 2 years to build my truck to where it is now and I love it.
