New 5inch
Old Feb 8, 2010 | 08:33 PM
joey's Avatar
Default New 5inch
I just put on my new flow pro turbo back 5inch from mighty diesel and its sick. There is only one little problem i am haven trouble making the sprare tire fit under there without touching the pipe. It fits under there but the tire hits and i am worryed about it melting the rubber. Will the pipe get that hot? And i am open to any opinions or advice thanks
Old Feb 8, 2010 | 08:49 PM
jbrown1132's Avatar
you could mod the exhaust pipe with a hammer or adjust your exhaust hangers to give some additional clearance. or you could go for the baja look and mount the tire in the bed
Old Feb 8, 2010 | 09:31 PM
R&RDiesel's Avatar
FormerVendor
Wrap some heat wrap around the part that hits the spare tire. You will be fine.
Old Feb 8, 2010 | 10:09 PM
Shea@L&N Performance's Avatar
FormerVendor
I wouldnt imagine it getting hot enough to melt your tire but as stated above move the hangers a little bit or put some heat wrap on it. What size tire is your spare?
Old Feb 8, 2010 | 10:33 PM
12valvetater's Avatar
I just took my spare out.
Old Feb 9, 2010 | 08:18 AM
FormerVendor
Mine is out also
Old Feb 9, 2010 | 09:28 AM
Yes, it will get hot enough to do some damage to your tire.
Old Feb 9, 2010 | 09:34 AM
joey's Avatar
I will just leave the tire out.
Old Feb 9, 2010 | 10:02 AM
If your putting it in the bed - make sure you secure it because it can be a dangerous projectile if you get into an accident.
Old Feb 10, 2010 | 09:40 AM
joey's Avatar
Also i dont want anyone stealing it.
Man i moved the hangers and stuff and it still dont fit so next thing is to move the tire winch back and hopefully that will fix the problem.
