what do i need
Old Feb 8, 2010 | 03:24 PM
cumminskid92's Avatar
Default what do i need
would an H1c and H2c make a good twin turbo set up. also if i already have the turbos what else would i need for the set up
Old Feb 8, 2010 | 04:29 PM
tltruckparts's Avatar
i dont know much about twins but i dont know why youd ever want an h1c in the first place. id use at least an hx35
Old Feb 8, 2010 | 07:40 PM
93_Fummins's Avatar
I was also wondering about an H1C as a top charger in a twins setup... I realize they are not wastegated, so tuneability is nill...but what if you added an external wastegate? The only reason I'm considering using the H1C is because I was one of the many 60mm compressor upgrade chumps with my 1st gen and since I already have it I figured I'd see if I could use it...
Old Feb 8, 2010 | 07:56 PM
welderboy250's Avatar
it could be made wastegated. u can buy the housings off of hx35's rather reasonable
Old Feb 11, 2010 | 09:01 PM
they made a wastegated h1c. i have one
Old Feb 11, 2010 | 09:33 PM
i believe the wh1c was stock on 94 p pump trucks
Old Feb 11, 2010 | 10:55 PM
seandonato73's Avatar
it was my uncles 94 12valve has one..... just had to replace it
