Injectors vs. Nozzles
Old Feb 8, 2010 | 10:54 AM
jake 94's Avatar
Default Injectors vs. Nozzles
Whats the difference between hole injectors and nozzles. different in power wise or whats the deal??? thanks guys
Old Feb 8, 2010 | 10:57 AM
Full Injectors are ready to drop into your truck. Nozzles have to be put into your injector bodies and pop tested to spec. If you have a local injector guy that can build and pop test injectors for a fair price you can save some $$$. If not then I would get full injectors.
Old Feb 8, 2010 | 12:25 PM
jake 94's Avatar
are full injectors better then nozzles or are they the same thing?
Old Feb 8, 2010 | 12:43 PM
01quadcab's Avatar
it depends on what brand your buying. If you go with a bigger name your better with whole injector.
Old Feb 9, 2010 | 08:40 PM
LawnScum's Avatar
i went with the BD-pulce 150 nozzle's and so far i like them. there a little smokey but not to bad if i keep my edge off. is you dont have a programmer that taps the pump wire they reelie dont feel any differnt then stock in my mind. i had my nozzles put in pop tested etc for 20$ per injector
Old Mar 2, 2010 | 03:51 PM
blkjack's Avatar
I am looking a possibly upgrading to some bigger injectors now as well and was wondering the same thing about nozzles vs drop in injectors. Also what would be a good size to upgrade to on the truck in my sig and still be a good dd and be able to ocassionally tow but also most importantly gain me some decent HP?
Old Mar 2, 2010 | 08:27 PM
LawnScum's Avatar
i ran 100 h.p injectors with a stock turbo,smarty and powerpuck. and my egts were a little hot, only when i towed or ran it reel hard threw all the gears. with the quad like you have i prob would run anything smaller then 100's and you should be fine.
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
scottxmorris
9
Oct 2, 2014 01:59 PM
