micro pump?
Old Feb 7, 2010 | 09:27 PM
brindle_bull's Avatar
Default micro pump?
i have a 95 12v and sometimes on a cold morning i start it and let it build oil pressure and then when i go to back out it dies. but if i let it run for at least 60 seconds it doesn't die. so i used to have several 80s model ford 6.9s that i had micro pumps on to keep good fuel pressure on. i was wondering if i put one of these micro pumps in the fuel line some where to get a few more lbs of fuel pressure would it help, hurt or neither???
Old Feb 7, 2010 | 09:38 PM
dan33klein's Avatar
what is your idle set at? if the idle is a tad to low and you drop it in reverse before its completly warmed up and running at the right idle speed it will die. check that out
Old Feb 7, 2010 | 09:41 PM
i thought about that too i do think it might be a tad low....what rpm should it idle at warm?
Old Feb 7, 2010 | 09:48 PM
Very likely if you bump your idle the problem will go away:
Heres a how-to: Ram Diesel Problems
You could also install a fuel pressure guage.
Old Feb 7, 2010 | 10:01 PM
ok so if idle adjust fixes the problem, is there no benefit to the pump? ....i have 2 of these pumps and they were 50 bucks a pop and i kinda wanna find a use for em if not...anyone need one?
Old Feb 7, 2010 | 10:09 PM
captain_stabbin's Avatar
if it was a fuel problem it would do it all the time not just when its cold,
Old Feb 8, 2010 | 12:04 AM
How much psi do they make? The P-7100 needs a lot of pressure. 25 psi at idle and up to 35-37 psi at WOT, iirc.
Old Feb 8, 2010 | 06:54 PM
yea neither of the pumps get 35 so they would be just a restriction rather than a help so never mind to that idea...i suppose i have extra transfer pumps now for my aux fuel cell...thanks for the comments evil
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
Renteria1217
Apr 16, 2015 11:38 PM
B.k. Smith
10
Jan 7, 2015 02:29 PM
