New seats
Old Feb 7, 2010 | 09:20 PM
12valvecory's Avatar
Default New seats
I was just wondering if newer dodge seats or any other make of truck would have the same seats or at least some that i could get to fit in my dodge because i cant find any leather seats made for my truck but can find chevy and ford? thanks
Old Feb 8, 2010 | 05:47 AM
TwinStackPete379's Avatar
seats would work from newer dodge. but you would have to modify the brackets that mount to the floor. I imagine all seats would just have to make brackets for them. Also if you got power seats that might be a challenge to wire in right. Idk. And i guess it also depends on how much room you have to work with.. sorry im not much help.. good luck
Old Feb 8, 2010 | 02:32 PM
Later second gen SLTs had the seat belts coming out of the seats. This is not what you want.
Id look at third gen seats - but you will have to modify the brackets under the seats to get them mounted.
Old Feb 9, 2010 | 11:46 AM
PhilipR's Avatar
Ford seats would be the best.....they sit flat so all you need is a riser in the front for the dip in the floor IIRC.
Old Apr 29, 2010 | 12:52 AM
manny31's Avatar
put a set of dodge 05 seats in mine was not that hard a little cutting and welding did it. seatbelt clip changes so either cut the center off yours or get belts
JPT18
Mar 6, 2016 11:20 AM
ramrunner01
Jan 21, 2015 09:29 PM
DMAX51
Chevy/GMC Duramax 01-04 LB7
Oct 22, 2014 01:39 PM
fordboy10
Oct 12, 2014 11:16 PM
