temperature
Old Feb 7, 2010 | 01:27 PM
luke46's Avatar
Default temperature
With my setup what temp should I be running. I can tow a light load and run close to 1k doesn't seem right on flat land. normal driving with my 4.10s at 65 and I'm over 600 easy. How do I get my temp down if that's too high?
Old Feb 7, 2010 | 01:39 PM
RAW's Avatar
RAW
I don't think 1000 is too bad. I roll on the hiway at 700-800 depending on the road. Want it cooler? More air!
Old Feb 7, 2010 | 02:21 PM
blkjack's Avatar
X2 time for a bigger turbo for cooler EGT's
Old Feb 7, 2010 | 06:08 PM
turbo20psi's Avatar
My 01 runs about 700-800 no load,with the EGT sensor before turbo 4.10s.My 02 runs 600 before turbo but its compounds with 3.54s.With a 6,000 pound load on the 01 runs 900 or so.
Old Feb 8, 2010 | 09:59 PM
luke46's Avatar
I guess it sounds semi normal. thanks
Old Feb 8, 2010 | 10:17 PM
RAW's Avatar
RAW
Tonight I paid a lot of attention to the conditions, here is what I found:
Outside Temp : 23 F
Speed :65 MPH
Boost : 9 to 10 lbs
EGT's: 700 +/- 40 depending on the grade. The road was pretty flat
No head wind.
Old Feb 10, 2010 | 01:08 PM
luke46's Avatar
Ya I guess that's pretty similar to mine. thanks
trd3rdasslt
Jul 14, 2015 09:23 AM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
robbyS
Apr 16, 2015 02:22 PM
Oleoleson
Chevy/GMC Duramax 01-04 LB7
Mar 31, 2015 05:22 AM
