getrag top cover question
Old Feb 7, 2010 | 11:49 AM
tltruckparts's Avatar
Default getrag top cover question
ok so i changed out my top cover the other day when my old one crapped out. when i took my old one off, there was no gasket between the top cover and the housing, and it never leaked with the 90w that was in there. but now that i have a synthetic oil in there its leaking.
does anyone know if there is supposed to be a gasket inbetween the two or not?
Old Feb 7, 2010 | 06:12 PM
seandonato73's Avatar
i used rtv to reseal mine when i had the tranny out for the clutch. no leaks so far
Old Feb 7, 2010 | 10:24 PM
do you know if its supposed to use it normally? or did you just do it for extra protection
Old Feb 8, 2010 | 01:58 AM
pewder's Avatar
Would you rely on a pull-out method or wrap it?
The extra protection is worth the headache that comes from not using it.
ha ha ha
Old Feb 8, 2010 | 11:34 AM
thats funny
i just wanted to know if they normally use one because if they dont and mine leaks and no one elses does must have another problem somewhere.
Old Feb 8, 2010 | 08:04 PM
welderboy250's Avatar
a rebuild kit comes witha gasket for the top cover and i assume they had one from the factory but i just use rtv and mine never leak.
Old Feb 8, 2010 | 09:15 PM
i just did it today with rtv and so far no problems!
Old Feb 10, 2010 | 05:28 AM
freak007's Avatar
Early getrags used no gasket...
Later there was a TSB about leaks (amazing... no gasket and now we have leaks), so later Getrags got a gasket as well as some older ones had gaskets installed...
Old Feb 10, 2010 | 06:04 PM
big bad diesel 416's Avatar
Site Sponsor
the gasket acts as a shim and a seal it holds the shift forks up off the collars to prevent premature where and also seals the top of the case
quiksilver1j
Jul 30, 2015 12:41 PM
carid
Diesel Bombers Sponsors
Jul 16, 2015 05:11 AM
Ryans71
Jan 14, 2015 07:52 PM
Nov 12, 2014 08:10 AM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
