Rail pressure
Old Feb 7, 2010 | 11:59 AM
dangerous1965's Avatar
Default Rail pressure
anybody have a link to a wiring diagram for a quadzilla monitor? trying to figure out the wire for the rail pressure I'm only reading 12500??? I used to read 21000 to 25000 depending on my MP-8 position!
Ok I verified the wiring now anybody know why a truck would have rail pressure around 4600 psi??? This # is way off! I think this is a false reading because the truck runs fine!
Except the MPG are in the dumps!
Last edited by dangerous1965; Feb 7, 2010 at 11:59 AM. Reason: Automerged Doublepost
Old Feb 9, 2010 | 06:12 PM
thebreeze04's Avatar
Is the CP3 stock??
Old Feb 9, 2010 | 06:23 PM
I have an Arson Kit on it.
Old Feb 9, 2010 | 06:29 PM
could be a bad sensor or maybe the limiting valve on the rail. Is it reading 4600 at idle or higher in the rpm range??
Old Feb 9, 2010 | 09:02 PM
Yeah 4600 at Idle and climbs to 11 to 12k at full throttle.
Old Feb 9, 2010 | 10:04 PM
cerberus60's Avatar
I think you broke it.
Unless you did something to the monitor I would be worried you have a problem. The mileage going down could indicate just that.
Old Feb 9, 2010 | 10:14 PM
If only tou had High pressure caps to deadhead the cp3 at the rail
Old Feb 10, 2010 | 08:39 AM
Any way to verify rail pressure thru the ECM? The quadzilla commander just taps the MAP sensor for the reading. Not sure how acurate this is but it used to say 21 to 23k then I took out the max milage module and it changed? Waiting on a reply from them!
Old Feb 10, 2010 | 05:56 PM
cerberus60's Avatar
Yes, a scan tool capable of reading the ECU will tell you what the ECU is seeing from the RP sensor. Does the commander tap the RP sensor or plug into the data port under the dash?
Old Feb 10, 2010 | 07:48 PM
Red_Rattler's Avatar
High Tech Redneck
What order did you plug them in? Gauge first then mp8 otherwise If you have the mp8 first, your reading the fooled pressure from the mp8 which allows the cp3 to command more than it's actually seeing.
AlsLAoso here's the link to the manual....
http://www.quadzillapower.com/files/...Instr_6_09.pdf
Last edited by Red_Rattler; Feb 10, 2010 at 07:48 PM. Reason: Automerged Doublepost
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Gitana
Feb 18, 2015 10:08 AM
veggyoilkid
Nov 10, 2014 12:39 PM
growland415
Oct 22, 2014 01:56 PM
