injectors
Old Feb 6, 2010 | 04:12 PM
jake 94's Avatar
Default injectors
im looking to get some injectors for my 24v im getting and i was wondering where i could get some 120-150 horse nozzles or injectors for less then $600
Old Feb 6, 2010 | 05:01 PM
RAW's Avatar
RAW
I can tell you what I did. I bought 50 - 60 horse nozzles from Luke when they were on sale. I removed my injectors and sent them and the nozzles to a local diesel shop to be swapped. After the deal from Luke, and the price from the diesel shop, I ended up paying $330 Canadain for 50-60 horse injectors, pop tested. To jump up to 120's or 150's, add about $80 or $100 I figure. Keep you under that $600 mark.
Hope that helps.
Old Feb 6, 2010 | 08:40 PM
Codgedodger's Avatar
FormerVendor
PM sent
Old Feb 6, 2010 | 09:48 PM
chpmnsws6's Avatar
What kind of EGT's would you see with 125's over a set of RV275 injectors? RV275 run around 900 degrees on the good size hills. What is a safe EGT Limit?
Old Feb 7, 2010 | 06:10 PM
FormerVendor
1500 is pushing your luck... 1300 is as far as I would go...
Old Feb 7, 2010 | 07:06 PM
turbo20psi's Avatar
Luke has good deals,what do u want to do to your truck in the future 150s are good will yeild a 2-3 mph gain and good power with egts in a comfortable limit .That is what I gained ,200s and above you be want a big turbo or compounds my vote is compounds.Do you tow?
Old Feb 7, 2010 | 10:36 PM
How much snow ya got Mike?
Old Feb 8, 2010 | 09:29 AM
turbo20psi's Avatar
30+ inches and more to come.
Old Feb 8, 2010 | 09:30 AM
Old Feb 8, 2010 | 06:40 PM
dennhop's Avatar
Could always check out the used classifieds, I just found my Scheid 150s for 450 shipped...
