96 12v q's
Old Feb 3, 2010 | 10:26 PM
IH1206's Avatar
Default 96 12v q's
i am gettin a bone stock 96 12v in a coupla days, has 150,000 miles, and wanted to know if i put maybe 370's and 3k or 4k springs with a little change to the fuel plate (and yes im running a pyro) if the truck wil run hot or what, o ya and it only runs 18lbs of boost maxed out, my truck runs 45lbs maxed out and the turbos are BARLEY different in output and size and all i had was fuel plate slid forward and bigger intake, so what do i do with the wastegte to run more boost out of this turbo thats close to 35lbs without blowin up the turbo on this new truck
o ya on a 96 is there a screw u can turn to turn up the pump??
is there a screw u can turn on the 96 12v's to turn up the pump??
Old Feb 3, 2010 | 10:37 PM
12valvetater's Avatar
You have me fairly confused, but yes gov springs and 370s will be hot.
Old Feb 3, 2010 | 10:46 PM
IH1206's Avatar
if i tightened the flap screw on the wastegate, wil that keep it cool enough for a safe runnin temp, idk how much more boost it would run or effect it
Old Feb 4, 2010 | 05:37 AM
TwinStackPete379's Avatar
You got an Aftermarket charger? If not your truck is gonna run hott. I got 370's and a small charger. I hate it.
Old Feb 4, 2010 | 09:08 AM
wes-cummins's Avatar
use boost elbow to get more boost, there a star wheel on top the afc and screw on back of the afc, those 2 controll the boost fueling, sliding the plate gives you more top end fuel
Old Feb 4, 2010 | 03:36 PM
5.9Bronco...eventually's Avatar
whatever you do I have read everywhere to not run marine 370s. because they are not the right spray pattern
Josh Chretien
Mar 1, 2015 06:00 AM
Tory4
For Sale
Feb 1, 2015 08:33 PM
StreetRat
8
Jan 15, 2015 03:45 PM
cummin_not_strokin
Dec 31, 2014 03:28 PM
Oct 30, 2014 08:10 AM
