changing injectors
Old Feb 3, 2010 | 07:34 PM
bowtech's Avatar
Default changing injectors
any special tricks? i have to bleed them after i change them or any thing?
Old Feb 3, 2010 | 08:09 PM
ArizonaRedneck's Avatar
after you get them changed and tightened back up just loosen #1 fuel supply line and crank over until it spits fuel tighten it up and work your way down the line probably wont try to start until youve done 3or4
Old Feb 3, 2010 | 09:05 PM
bowtech's Avatar
so you crack the line and then pump the fuel primer?
Old Feb 3, 2010 | 09:25 PM
captain_stabbin's Avatar
mine usually fires right up without bleedin lines
Old Feb 3, 2010 | 09:42 PM
bowtech's Avatar
could air get stuck in the system if u dont or it just blow out
Old Feb 3, 2010 | 11:11 PM
you can pump the primer or crank it over either way will work and like captain stabbin says they have been known to start too without priming them
Old Feb 4, 2010 | 05:59 AM
94 12valve's Avatar
change the washers out even if they look good. The injectors have a button on the side make sure it drops in the slot in the head before you tighten them down. If the injector gets stuck go buy a nut that fits over the threads and use a pair of vicegrips to get it out.
Old Feb 4, 2010 | 10:39 AM
Hammer's Avatar
Actually....
If he cuts a short piece of electrical conduit pipe(just long enough that it fits between the head and midway up the injector) and uses a factory lug nut flipped over he can pull the injectors out very easily.Cheapest injector puller one can ever have and it makes removing number 6 a breeze.......Andy
Old Feb 4, 2010 | 01:14 PM
94 12valve's Avatar
Originally Posted by Hammer
Actually....
thats good advice, I've never had to use a puller with mine ( guess I have been lucky), normally I use a nut and a vicegrip and they come right out. I'll have to try this next injector go arround
Old Feb 4, 2010 | 07:30 PM
bowtech's Avatar
do i have to take off a bunch of stuff like all the fuel line holders or just take off the top nut on the injector?
