ts performance mvp
Old Feb 2, 2010 | 10:00 PM
02WhiteandBlack's Avatar
Question ts performance mvp
Well the problem with my truck that i thought was my lift pump was my chip so im in the market for a new one i was just wondering if the MVP tapped the pump wire if not i think i may go with it or if it does go ahead and get a edge comp or tst pm3 what do yall think?
Old Feb 3, 2010 | 12:08 AM
smokin' goat '01's Avatar
If you don't want to tap the pump wire I would suggest going with a smarty. If you want to tap the wire I would suggest a drag comp. I also hear a lot of good things about the quad Adrenaline but I have no personal expirience with it. Also, if you haven't already, you will need a lift pump upgrade or you will kill your injection pump. Gauges will also be needed to keep an eye on EGT's and fuel pressure. A clutch will probably be in your near future too. Hope this helps
Old Feb 4, 2010 | 05:41 PM
Well we replaced the lift pump with a some what performance one and im gonna do gauges before anything so how much pressure the pumps pushin will determan if i get a chip or a good LP like a fass or airdog first
Old Feb 4, 2010 | 08:53 PM
Dodgehunter84's Avatar
I've had a Edge drag comp and a TST Powermax comp. The edge comp is a great box, really liked it smooth power. The TST just didn't seem to fuel that hard on my HO truck but my buddy put it on his SO truck and it made a big difference. I'm running a Quad ADR now and love it. On my truck it fuels alot harder than the tst or edge. The Edge Juice with attitude is another good one. You could buy the Quad ADR with the pulse monitor or the Edge Juice with Attitude and you would get guages as well.
Old Feb 4, 2010 | 09:08 PM
when you get those you just get the gauges not the senders and stuff right?
Old Feb 4, 2010 | 09:32 PM
I think you have to get the fuel pressure sender, but it comes with the egt probe and it reads boost pressure from the map sensor.
Old Feb 4, 2010 | 09:42 PM
how much do the fuel pressure senders cost?
Old Feb 6, 2010 | 08:40 PM
you would have to look on quadzilla's website. it is Quadzilla Performance - Home
Old Feb 6, 2010 | 08:46 PM
The Adrenaline comes with everything you need except the fuel pressure kit. The Edge Juice with Attitude comes with everything.
You could also do an Edge Comp and Mech Gauges.
Let me know if I can help.
Luke
Old Feb 6, 2010 | 08:59 PM
I was hoping you would chime in luke.
