BD- super B special
Old Feb 2, 2010 | 06:43 PM
LawnScum's Avatar
Default BD- super B special
i just recieved the super B special. waiting on some other parts. i wanted to know if anybody has this turbo? and how it is. i have whats done to my truck in my SIG, how will my EGT'S be and will it spool up fast?
thanks
Old Feb 3, 2010 | 07:10 AM
cummins724's Avatar
I love my Special. I have 4.10 gears & it lights at 1400rpm. I tow very heavy & as long as I keep rpms over 2000, I get zero surging. I run Adrenaline PL03, Smarty sw3 when towing.
Old Feb 4, 2010 | 08:04 PM
LawnScum's Avatar
how much boot you poushing? i just instaled mine,broke it in and let it rip and im only seeing like 15 psi. i dont have my new injectors in it yet. could that be the problem?
Old Feb 4, 2010 | 09:38 PM
cummins724's Avatar
I have it wastegated at 45psi, but I still see 62psi with the Adrenaline on kill. I bet you have a boost leak.
Old Feb 5, 2010 | 03:32 PM
LawnScum's Avatar
you were right. intercooler boot closet to the turbo. i got new clamps and cleaned it with brake cleen. its alot better now. it is very laggy. will my new injectors help?. my stock turbo feels faster for some odd reason
Old Feb 5, 2010 | 04:00 PM
01quadcab's Avatar
what injectors are you currently running? What are your new injectors? try running without the smarty.
Old Feb 5, 2010 | 04:49 PM
LawnScum's Avatar
without the smarty helps a lilttle bit. i have stock injectors now. my new ones are BD pulce 150 h.p
Old Feb 5, 2010 | 05:00 PM
mikmaze's Avatar
trick to makin power out of that setup starts with a good fuel supply, air dog or fass setup, then the smarty, with a box and tapped wire to realy wake up those injectors.
Old Feb 5, 2010 | 06:08 PM
cummins724's Avatar
You need spring loaded clamps, the stock boots are fine for up to 45psi.
Old Feb 5, 2010 | 09:00 PM
LawnScum's Avatar
thats what i did for clamps. its holding good now im just hopeing those injectors will give me some good results. the turbo has alot of lag. ex on top end. 5th gear if i mash it at 1800rpm. it take a second to spool and it trows me in the seat.
