ok to run 2 stroke in my fuel with an air dog 150? Read more: http://www.dieselbo
Old Feb 2, 2010 | 05:16 PM
asabadin's Avatar
Default ok to run 2 stroke in my fuel with an air dog 150? Read more: http://www.dieselbo
tried posting in the Air Dog section didn't get an answer. I am doing my install this weekend. thanks for the info guys
Old Feb 2, 2010 | 05:42 PM
redneck_cummins's Avatar
Yeah you should be okay, I run 2 stroke in my fuel and I have the airdog 100. Here's a quote from Uncle Bubba's post on a draw back:
Originally Posted by Uncle Bubba
I'll go first. I think 2 stroke is a great idea and did improve mileage to a small extent. HOWEVER, I did find a downside to it. I started having fuel leaks all over the place. Both in my replacement high pressure fittings and the only stock fitting I had left on the truck. It losend all of em up better then any penetrating oil could have. Just something to watch out for if you use it.
Hope this helps and if you need any more info check out this thread https://www.dieselbombers.com/altern...il-thread.html
Andrew
Old Feb 2, 2010 | 05:56 PM
asabadin's Avatar
thanks. that's so true, after 3 full tanks I had some small fuel leaks that needed to be tightened. also, how ofter do the air Dog filers need to be changed?
Old Feb 2, 2010 | 06:10 PM
No problem man Not to shure on when to change the filters, the first time I changed mine was when I noticed my fuel pressure was getting lower than normal. Maybe someone else will chime in with the correct answer to help you out.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
