How much boost
Old Aug 21, 2007 | 03:04 PM
Default How much boost
I don't lay my foot into it to often but the other day I did and I noticed that my boost during 1st, 2nd & 3rd gear was ~15-18 psi.
What should a stock turbo with a stock wastegate put out?
Old Aug 21, 2007 | 03:35 PM
Uncle Bubba's Avatar
With your quadzilla having the boost fooler you should be able to knock 30plus psi pretty easy I think.
Old Aug 21, 2007 | 03:47 PM
Johnny Cetane's Avatar
i'd start looking for boots that are off or leaking.
Old Aug 21, 2007 | 10:11 PM
Boots are OK and I thought the XZT+ just changed the timing.
Went for a quick drive, acceleration feels real good. Going on the onramp, before hitting the freeway and I am over 80 without a problem. With a little power braking tires will spin. If it could go up to 30psi of boast this truck would haul a#$. Are you sure about 30 psi?
Old Aug 22, 2007 | 07:46 PM
Cameron's Avatar
with my EZ i can get 21-22 psi i imagine you should be close to that if not more because the XZT+ does fueling also without tapping the wire so it can't be that much fuel...
Un4givn
10
Apr 27, 2015 01:58 AM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
Crews8r
Dec 21, 2014 07:35 AM
