Help! Need info. on 99-01 NV5600 6 speed
Old Feb 1, 2010 | 09:48 PM
ridenslide's Avatar
Default Help! Need info. on 99-01 NV5600 6 speed
I have a 2000 Dodge 2500 2 wd, with the earlier model NV5600. I believe this model has the smaller input shaft. Currently I have only reverse and a little bit of 5th gear and am in need of a new tranny! This will be my second. Can I upgrade the earlier NV5600 (99-01) to an after 2001 NV5600? What does this entail? Any info would be appreciated as I can not find the NV5600 for 99-01. I need my truck running!!!
Old Feb 1, 2010 | 10:07 PM
ArizonaRedneck's Avatar
welcome to diesel bombers and will this info help any https://www.dieselbombers.com/5-9l-1...-12-valve.html
Old Feb 1, 2010 | 10:27 PM
ridenslide's Avatar
Thanks so much! Anything helps at this point. So basically, to use a later model NV5600, I just need to have the drive shaft altered and have the later models fly wheel, clutch and such. Now if I can find any one in the San Diego area willing to work on it. Have not had any luck with that either!
Old Feb 1, 2010 | 10:41 PM
Uncle Bubba's Avatar
Your seein the downside of the 5600 now. They are great trannies when they work but when they don't. About the only place that will work on them is the big truck semi service center.
Old Feb 2, 2010 | 12:23 AM
Gear Poet's Avatar
If you've already got the early 5600 with the small shaft, I don't believe you have to shorten the driveshaft to install an upgraded 5600.
(The information linked above is a bit confusing - the person was swapping out a 4500 for a 5600, and I think he was comparing 4500/5600 transmission lengths in the third paragraph.)
Old Feb 2, 2010 | 03:57 AM
Diesel Dummy's Avatar
only difference in old and late 5600's is the input shaft, that can be updated.
Old Feb 2, 2010 | 10:00 AM
The bigger input shaft was introduced in August of 99. The earlier shaft was 1 1/4" 12 spline and the upgrade was 1 3/8" 29 spline
Ram NV5600 specs
Old Feb 2, 2010 | 10:22 AM
DeLuzGN's Avatar
I haven't been here, but this guy specializes in Dodge Cummins and he's in El Cajon. Might be worth a call to him to see if he can help you or point you in the right direction:
JT DIESEL PERFORMANCE - San Diego Dodge Cummins Shop
Old Feb 2, 2010 | 01:13 PM
Quad 4x4 - Home
Old Feb 17, 2010 | 09:46 AM
AndyMan's Avatar
Not that anyone asked... but just out of curiosity... what about swapping in a G56? Would compatibility problems would you have to overcome?
cjt8569
Sep 29, 2015 06:39 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Dertyd
24
Jun 7, 2015 02:45 PM
May 17, 2015 12:10 PM
F250MACH
Apr 26, 2015 05:19 PM
