whats the bar on a injector?
Old Feb 1, 2010 | 06:24 PM
bowtech's Avatar
Default whats the bar on a injector?
i just got a set of 215s and the bar is 260 what does that mean?
Old Feb 1, 2010 | 06:40 PM
shortbusdriver's Avatar
1 bar = 14.5 psi
It is opening pressure or pop off pressure of the injector
260 bar = 3770 psi
Old Feb 1, 2010 | 07:15 PM
bowtech's Avatar
so does that mean its a higher bar than a normal 215? that good or bad?
Old Feb 1, 2010 | 07:33 PM
260bar is what 215 injectors are rated for
Old Feb 1, 2010 | 07:53 PM
bowtech's Avatar
ok sweet
Old Feb 2, 2010 | 05:26 PM
TwinStackPete379's Avatar
The bar, decibar, centibar, and millibar are defined as:
  • 1 bar = 100 kPa (kilopascals) = 1,000,000 dynes per square centimeter (baryes) = 0.987 atm (atmospheres) = 14.5038 psi
  • 1 dbar = 0.1 bar = 10 kPa = 100,000 dyn/cm2
  • 1 cbar = 0.01 bar = 1 kPa
  • 1 mbar = 0.001 bar = 0.1 kPa = 1 hPa (hectopascal) = 1,000 dyn/cm2
Example conversion: 1 atm pressure = 1.01325 bar = 1.01325 x 105 Pa = 1.01325 x
105 N/m2
The word bar has its origin in the Greek word βάρος (baros), meaning weight. Its official symbol is "bar"; the earlier "b" is now deprecated, but still often seen especially in "mb" rather than the proper "mbar" for millibars.
The bar and millibar were introduced by Sir Napier Shaw in 1909 and internationally adopted in 1929.
FYI ...
Dkolanski06
Apr 23, 2015 09:32 AM
2ndcummins1
Mar 9, 2015 10:01 AM
amztroyer
5.9L 24V Performance
Mar 5, 2015 05:02 PM
12vbomber
Nov 11, 2014 10:58 AM
motormayhem
Nov 1, 2014 01:24 PM
