Erratic Tach Operation
Old Feb 1, 2010 | 04:11 PM
jfoose's Avatar
Default Erratic Tach Operation
Just have a question about the tach in my truck. This past weekend I noticed that the tach would jump around a little when its at idle. Normally the needle would sit around 700 rpm at idle, with normal variations as the truck idled (probably less than 50 rpm up down movement). Now I am noticing it ill drop down to 500 rpm, then all of a sudden surge back up to 700 rpm or slightly above. I notice when it drops down to 500 it is almost like it shuts off. There is no small movement of the needle at all. It seems like a manual tach if there was something wrong with the drive gears. Anybody had this happen to them. All the gear I'm running is in my signature. I'm running 3 on the smarty. Thanks!
Old Feb 1, 2010 | 04:28 PM
DB Admin's Avatar
Banned
Maybe intake headers cycling? or CPS
Old Feb 1, 2010 | 05:24 PM
jfoose's Avatar
Not familiar with that? What is CPS, and why would the intake headers be cycling?
If you meant intake heater, that usually doesn't move the rpm more than 50 to 100 or so. Still don't know what CPS is?
Any other ideas?
tur370
May 17, 2015 04:00 PM
tur370
May 14, 2015 08:09 PM
gp98
Apr 1, 2015 07:08 AM
Smilinjack
Feb 5, 2015 05:32 PM
short12
Jan 2, 2015 04:56 PM
