need pyrometer wiring not the probe I have that
Old Jan 31, 2010 | 07:21 PM
01quadcab's Avatar
Default need pyrometer wiring not the probe I have that
I bought a set of gauges a while back from a guy and everything looked fine in the box. I pulled them out today because I am helping a fellow bomber out with a set for his truck. I look at the pyro and find all this electrical tape around where the wiring the yellow shielding with black and red wires inside.. it's been clipped and all jacked up. I have a spare probe just no wiring. So maybe someone has a wire setup out there? If that makes sense
Old Jan 31, 2010 | 09:25 PM
tltruckparts's Avatar
just use some normal like 18 or 16 gauge wire whatever size it was before. all it is is electrical wiring
the yellow shielding i believe is just like a protective heat shield stuff should be able to find it at any local auto store
Last edited by tltruckparts; Jan 31, 2010 at 09:25 PM. Reason: Automerged Doublepost
Old Jan 31, 2010 | 10:35 PM
01quadcab's Avatar
so length doesn't matter?
Old Jan 31, 2010 | 10:53 PM
nope it shouldnt. i hacked mine up, rerouted it and cut it to turn with my trucks interior, and it has never changed the slightest bit. length of wire will not add any resistance at all. all the probe is is a resister that changes with heat same way a water or oil temp gauge will work. just make sure its heat wrapped where it matters, and other than that, its just wire. hope that helps
Old Jan 31, 2010 | 11:51 PM
01quadcab's Avatar
Thanks. I will let the guy know but will see if I can't get the correct wire setup for him.
Old Feb 13, 2010 | 09:33 AM
njneer1's Avatar
Dieselmanor.com has the wiring under "gauge accessories"
cumminspwr11
12
Oct 17, 2021 03:50 AM
yzrider250
Diesel Engine Conversions
Aug 10, 2015 11:33 AM
Forks diesel nut
Jul 27, 2015 12:19 PM
OBSBEN
Audio Equipment/Electrical
Jan 6, 2015 07:40 AM
Mike H
Nov 25, 2014 03:13 PM
