need adr help please
Old Jan 30, 2010 | 10:23 PM
dodge rodder's Avatar
Default need adr help please
has and body had a problem with the quadzilla adr. control pod not turning on. it worked fine when i parked it friday night and i updated it friday night and saterday mornig the damn control pod did not come on the engine started tho. NEED HELP
Old Jan 31, 2010 | 05:55 AM
Jazz's Avatar
I have never had it not come on. Did you check all your connections? Maybe unplug and plug everything back in and see if that helps. I would think it's just a bad connection some where
Is it the pod or the pulse control monitor your talking about?
Old Jan 31, 2010 | 06:57 AM
biged681985's Avatar
he said it was only th pod llast night when i was talking to him
Old Jan 31, 2010 | 07:36 AM
Jazz's Avatar
Ok, the original little pod that came with the Adrenaline before the pulse monitor came out? If so I have one around here some where if it is the pod that's bad
Old Jan 31, 2010 | 07:41 AM
cmnspwr05's Avatar
maybe try downloading the program again or like stated above check all your wiring connections...posibility something was loose and just came loose at the wrong time
Old Jan 31, 2010 | 09:39 AM
is the control pod (NOT THE PULSE) i down loaded a 2000 tune before all this started. i put a 1000 tune back on it this morning and going to try it a little bit later let you know
ok just tried it and still nothing it still started with it unplugged and it still starts with ard on it just the control pod dose not light up, this is pissing me off
is there any way of testing this thing to see if the pod is bad
Last edited by dodge rodder; Jan 31, 2010 at 09:39 AM. Reason: Automerged Doublepost
Old Jan 31, 2010 | 10:17 AM
cmnspwr05's Avatar
does it just not light up or does not show anything and is just blank?
Old Jan 31, 2010 | 10:19 AM
get ahold of someone tha has one with just the pod and hook it up to urs and see if its good or not would be the easiest. hit oklahoma6speed up, see if he still has his pod. other than that, idk how u would be able to check it out with out sending it to quadzilla. good luck
Old Jan 31, 2010 | 10:22 AM
cmnspwr05's Avatar
well im wondering if its just not illuminating since thats what i kinda understood in the last post but im not sure?
Old Jan 31, 2010 | 10:23 AM
well i got it fixed, i put the 3000 tune on it and it started working again, i dont understand it but thats electronics. i appreciate all the advice and help thanks to all
