how much pressure should a piston lift pump have?
Old Jan 29, 2010 | 03:06 PM
tjsmokin's Avatar
Default how much pressure should a piston lift pump have?
how much should the low pressure piston lift pump be putting out at minimum?
Old Jan 29, 2010 | 03:11 PM
RSWORDS's Avatar
They should put out 18psi, I think RichieO has sadi his doen more like 13 to 15 psi after the filter.
Old Jan 29, 2010 | 03:18 PM
ArizonaRedneck's Avatar
ya what rs says but now i cant remember where i read that
Old Jan 29, 2010 | 03:25 PM
tjsmokin's Avatar
ok. thanks. another member has them in stock and said they were form8-10 psi for $50. thought sounded a little low psi. would that be enough to fuel 350-400hp? of should i get the napa one for $150?
Old Jan 29, 2010 | 03:49 PM
tltruckparts's Avatar
if you plan on gettin big power like that, id look into an airdog or fass or something. but thats just my 2 cents
Old Jan 29, 2010 | 03:57 PM
tjsmokin's Avatar
id love to go that way if i had the funding. it was alot cheaper to just go with the piston pump
Old Jan 29, 2010 | 04:12 PM
stillcummin's Avatar
Ive never had one rune over 8psi new or old(after the filter)
Old Jan 29, 2010 | 05:34 PM
RSWORDS's Avatar
you are thinking of the diaphragm pump that comes stock, the piston lift pump is on 2nd gen 12v's and the Low pressure piston pump is from industrial/agricultural set-ups
Old Jan 29, 2010 | 05:42 PM
Richie O's Avatar
I see 12 to 13 psi after the filter and have seen 3 psi wide open. Thats at 300 hp tune. PToombs see's 14 to 15 with his but he runs a bigger fuel filter then stock.
Old Jan 29, 2010 | 05:55 PM
tjsmokin's Avatar
so the stock one for a 94/98 from kragen auto parts is the high pressure one? i guess ill have to go through cummins to get the low pressure one?
