Newbie ??
Old Jan 29, 2010 | 12:17 PM
desertmonkey's Avatar
Question Newbie ??
I took so me pictures to go along with my questions.
Should this Turbo waste gate hose be blocked off?
And the fitting on the waste gate is left open is this not where the Turbo waste gate hose goes?
Thanks,
L.
Old Jan 29, 2010 | 01:53 PM
94 12valve's Avatar
yes that is where the hose that is blocked off goes, your wastegate is modded so it will not open. That hose must remain blocked off or hooked up to the wastegate, other wise your afc will lose its air signal and you will have no power.
I personally like running with a wastegate to keep my drive press in check, but some do not.
Old Jan 29, 2010 | 02:39 PM
In having it blocked off how much does that affect my boost?
Old Jan 29, 2010 | 05:53 PM
mylilpwny's Avatar
depending on how much fuel you pushing ... but wat it does is prevent wastegate from opening meaning the boost just keeps building ... so you having to "drive by your boost gauge" ... im doing it right now ... untill i get my boost elbow .... but you should be fine just dont boost 2 much
and kudos for super clean engine bay ... mine is so dirty ... ... gues thats wat you get when building a chase tuck hahah
Old Jan 29, 2010 | 07:57 PM
Hammer's Avatar
Just remember than any boost pressures over 40psi on a stock turbo(WH1C-HX35-HY35) is not doing you any good at all.Once you cross the 40psi threshold all your doing is heating the air and running the charger out of its map.
Rescuedu
Aug 26, 2015 05:38 PM
AmberAlert69
Aug 23, 2015 09:02 AM
Mopar92
Jan 24, 2015 08:54 PM
ilovetacos
Dec 10, 2014 12:55 PM
plow_this
Nov 16, 2014 11:40 PM
