no blower help!
Old Jan 28, 2010 | 07:38 PM
stillcummin's Avatar
Default no blower help!
does anyone know what the little terminal is behind the glovebox on the upper/inner firewall?It exceptes the plug from my fan switch,but its blind in the engine bay.I have no power to the fuse for the fan either.Everything else is working so its not the ignition switch.I dont know where the thermo resistor is for the switch
Old Jan 29, 2010 | 05:01 PM
440warwagon's Avatar
That is a resistor for the fan speed's
Old Jan 29, 2010 | 05:23 PM
diesel chassis.pdf
Old Jan 29, 2010 | 05:35 PM
ArizonaRedneck's Avatar
this info is sketchy at best iam using the the wiring diagram from a w 150 andits the closest i could come up with it says your resistors or on the right side of the dash on top of the heater assembly and the power wire comes to the fuse box directly from the ignition switch could be a bad wire or bad connection in the ignition switch and it says the color of the wire is light blue
Old Jan 29, 2010 | 06:04 PM
yah Brown/blue off the fuse, the light blue goes to the ignition the brown goes to the switch,then back out with the other wires(switch positions) to the resistor,which is a bulkhead connection by the way.Its above the hvac box on the inner firewall.Pop your glovebox and have a look.
realtrucksrattle
Sep 20, 2015 10:24 PM
Aug 19, 2015 08:30 PM
Aug 7, 2015 12:40 AM
