turbo problem
Old Jan 28, 2010 | 03:08 PM
conner's Avatar
Default turbo problem
Since the other day, it sounds like my stock vgt turns off when I am crusing at a steady speed or when it is just idiling. Now when I say it sounds like it turns off, it like I turn on a smoke switch. "I had one 6 months ago". Do you think my vanes are stuck or a chaffed wire? Are there any known issues that y'all know of?
Old Jan 30, 2010 | 05:06 PM
powerstroke7's Avatar
I have heard that those smoke switches make your veins stick. They say not to put them on for that reason.
Old Feb 1, 2010 | 07:08 AM
tworks's Avatar
Clean your e.g.r. valve and your exaust back pressure snsr. / tube. Both of those can create puffing black smoke
Old Feb 4, 2010 | 03:12 PM
conner's Avatar
I will give that a try, thanks TWORKS. And thanks powerstroke7, hine sight is a pain.
Old Feb 4, 2010 | 04:14 PM
grabber1's Avatar
How do you go about cleaning an EGR Valve? Do you run some kind of cleaner through it or do take it apart somehow?
Old Feb 4, 2010 | 05:47 PM
DieselDanBoy's Avatar
just run a cleaner through it, spray it out with brakeclean probably, dont hold me to that i've never cleaned on just replaced and deleted
Old Feb 5, 2010 | 03:19 PM
conner's Avatar
Take out the 2 bolts that hold it on, remove the 2 orings and let it soak in break cleaner. If needed use a wire to brush off stubborn buildup
Old Feb 5, 2010 | 03:23 PM
grabber1's Avatar
Thanx for the info CONNER.
Old Feb 6, 2010 | 12:03 AM
conner's Avatar
No problem
burndiesel
10
Feb 7, 2023 01:15 AM
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
