exhaust to turbo
Old Jan 28, 2010 | 01:40 PM
dodgeflatbed's Avatar
Default exhaust to turbo
I have turned up my fuel pump and have adjusted the throttle along with more air intake. Could this power increased or air increasment cause the pipe to be "pushed off" the turbo? and is there a way to fix it without welding them together?
Old Jan 28, 2010 | 03:02 PM
ArizonaRedneck's Avatar
what pipe has been pushed off. more details please
Old Jan 28, 2010 | 05:17 PM
the main exhaust pipe has slipped off
Old Jan 28, 2010 | 06:44 PM
tltruckparts's Avatar
tighten up the v band clamp, that shouldnt ever come off if its tight there is no need to weld it up. if its all the way tight you got a problem somewhere the back outlet of the exhuast housing is cracked something but it shouldnt just fall off. more power would not make it fall off
Old Jan 28, 2010 | 09:41 PM
seandonato73's Avatar
x2
Old Feb 10, 2010 | 09:04 AM
92W250's Avatar
I know that my downpipe attached to the back of the turbo is in rough shape and the PO made a buggered up patch, but it still leaks some exhaust, especially when you tromp on it. But coming with the new exhaust will be a downpipe, so I'm saving my pennies up until then.
avatardvr
18
Aug 8, 2019 12:38 AM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
D-350 dually
Apr 11, 2015 11:38 PM
