01 24 valve died no start
Old Jan 28, 2010 | 10:29 AM
6.5coalroller's Avatar
Default 01 24 valve died no start
One of my buddies has an 01 24 valve with a quadzilla adrenaline and bd 100 horse injectors and bd lift pump. He let out of the throttle to stop at a stop sign and the truck died and now won't start. Lift pump is running and there was fuel in the filter at least. I have not had a chance to look at it, but thats what he has looked into so far. What can we check to figure out whats goin on. He said it was running fine before no loss in power. I figured if it was the ip it would have gave a sign that it was on it's way out but idk. Anybody???
Old Jan 28, 2010 | 10:40 AM
chpmnsws6's Avatar
What kind of fuel pressure does he have? Codes?
Old Jan 28, 2010 | 11:14 AM
I'm not sure i'd have to check tonight do you know if you can check for codes with the quadzilla.
Old Jan 28, 2010 | 11:41 AM
mishkaya's Avatar
Was he relatively hard on the throttle when he let off? If so he probably just needs to bleed the lines at the injectors to get back up and running. This has happened to quite a few in all reality. Hope it's something simple!
Old Jan 28, 2010 | 11:50 AM
Ok sweet we'll try that tonight.
Old Jan 28, 2010 | 11:57 AM
jesseb319's Avatar
i got a problem with this 2000 i just got the truck i guess got ran out of feul once but got fuel put back in well no i can get it running and the guy i got it from thinks it might need a new ip but idk cause you can her the pump running and i cracked the line on the lift pump and its spitting fuel but so i closed that and cracked the 1 3 4 injector to bleed it and 1 is dry and 3 is kinda spitting fuel and so is 4 im lost......... i hope i dont need a new pump anyone any help here? if anyone has a pump let me no please i just joined this site today cause one of my buddys told me to ask yall on here
Old Jan 28, 2010 | 01:18 PM
mishkaya's Avatar
Proper etiquette is to start your own thread if you have a different problem...
This said, if you have good fuel pressure to the VP44, but not fuel to all of the injector lines, you most likely have a failed VP44. How much did you crank with the lines cracked to the injectors? It can take a while to bleed all the air out of the lines if you ran the pump dry.
Old Jan 28, 2010 | 01:34 PM
jesseb319's Avatar
well i cranked on it for a little bit then it got to dark so im going to do it again today but lines 3 and 4 and some fuel coming out but not much and 1 was dry....
Old Jan 28, 2010 | 01:37 PM
mishkaya's Avatar
Should try cranking at least a dozen times if the tank was run dry. It can take a while to get the whole system primed. Just make sure the line to the VP44 is fully primed first, or you just might run out of battery...
Old Jan 28, 2010 | 01:53 PM
jesseb319's Avatar
how will i make sure the line to the pump is primed ?
moose2j
Jun 21, 2015 12:36 AM
PeteBug
Jun 11, 2015 12:16 PM
RayRay4991
Feb 23, 2015 07:45 AM
southernbelle14
6.0L Performance
Dec 29, 2014 10:53 AM
Tyler_302
Oct 22, 2014 07:08 PM
