Super HX40/16 and 14mm pump head
Old Jan 27, 2010 | 10:29 PM
Bad93Cummins's Avatar
Default Super HX40/16 and 14mm pump head
This is the turbo im looking at getting with the 4" downpipe hopefully in couple months, was wandering can this be used on a twin turbo set-up? Going to twin turbo it after i come back from uti from doing diesel/diesel industry and the cummins elective program. Alsoing going to O-ring head and 60lb springs.
Also was wandering, how come the 14mm pump head is unrealiable in a daily driven truck? just to much fuel is needed or to high rpm??
Old Jan 28, 2010 | 12:50 PM
1990cummins's Avatar
you could definately use int in a twin setup im using my stock h1c with a compressor housing and pin wheel from a 93 and a 12 cm wgt exhaust housing to feed a hx40 with a 18 cm exhaust housing and im running around 70 psi
Old Jan 28, 2010 | 02:04 PM
how does that set-up spool? Do you like it? Been also looking into HX35/HT3B twin set-up, talking to a guy with that se-tup.
Old Jan 28, 2010 | 02:30 PM
i love the set up that i have there is vitually no lag and it clears out almost instantly i could throw a whole lot more fuel at it and have no problems which im going to be buying injectors and a pump head soon i have a 60 psi gauge and it pegs the gauge rite back to 0 in a heart beat i have been lookin into the hx35/ht3b setup but im still running stock head studs and gasket and need to stud and o-ring it before upgrading turbos i do have a video on you tube of the truck but i cant post it in this section due to foul language but if u go on you tube and type in badass gen 1 cummins thats my truck doin donuts
Old Jan 28, 2010 | 03:37 PM
Budgreen's Avatar
I think you meant "wondering" ?
wan⋅der⋅ing
  /ˈwɒndərɪŋ/ Show Spelled Pronunciation [won-der-ing] Show IPA
–adjective
1. moving from place to place without a fixed plan; roaming; rambling: wandering tourists.
2. having no permanent residence; nomadic: a wandering tribe of Indians.
3. meandering; winding: a wandering river; a wandering path.
–noun
4. an aimless roving about; leisurely traveling from place to place: a period of delightful wandering through Italy.
5. Usually, wanderings.
a. aimless travels; meanderings: Her wanderings took her all over the world.
b. disordered thoughts or utterances; incoherencies: mental wanderings; the wanderings of delirium.
Old Jan 28, 2010 | 03:58 PM
RSWORDS's Avatar
wow, your really pushing those turbos out of there map.
Old Jan 28, 2010 | 04:08 PM
stillcummin's Avatar
with enough fuel this guy can break anything.
Old Jan 28, 2010 | 04:10 PM
RSWORDS's Avatar
huh?
Old Jan 28, 2010 | 10:32 PM
seandonato73's Avatar
?????? don't get it either
Old Jan 29, 2010 | 05:04 AM
just a bad joke,sorry!
