a518 question
Old Jan 27, 2010 | 08:07 PM
cumminsblazer's Avatar
Default a518 question
is the bellhousing the same on a gasser and a cummins cause a gasser 518 is way easyer to find then a cummins 518
Old Jan 27, 2010 | 10:35 PM
BC847's Avatar
You don't want a gasser A518 behind your diesel. They're not built as strong (internally) and the main governor is set too high for use with the diesel (shift points way too high).
Old Jan 28, 2010 | 12:25 AM
ok thanks im just having a hard time finding a tranny that is 4x4 to put behind my cummins
Old Jan 28, 2010 | 01:19 AM
tltruckparts's Avatar
im pretty sure theyre different. if i remember correctly i remember hearing that the bellhousing is alot different thats one of the reasons theyre so hard to come by
Old Jan 28, 2010 | 04:19 AM
pewder's Avatar
The V-10 gasser is the same as the diesel right? Atleast from my understanding it is the same.
Old Jan 28, 2010 | 10:06 AM
kensmachine's Avatar
The V10 is the only gasser transmission that has the same bell housing on it as the Diesel. The one thing you would need to change is the governor. I have herd you need to change the valve body also but I don't know why and some say you need to change the front pump in the transmission but I have looked at some parts books and they say that they are the same. ken
Old Jan 28, 2010 | 10:22 AM
BC847's Avatar
From the '93 FSM . . .
Old Jan 28, 2010 | 05:58 PM
So pretty much everything is different thank
Forks diesel nut
Diesel Engine Conversions
Jul 27, 2015 12:19 PM
Dodge2006/5.9
Jul 20, 2015 01:21 PM
99&91cummins
Mar 4, 2015 01:56 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
