Schaeffer Premium Diesel Visit - Schaeffer Premium Diesel
Two Stroke Oil Myth or Legend ?
Old Jan 27, 2010 | 01:27 PM
DB Admin's Avatar
Banned
Default Two Stroke Oil Myth or Legend ?
Please give us your interpretation of this
https://www.dieselbombers.com/altern...il-thread.html
Old Jan 27, 2010 | 01:31 PM
Fuel Dr Rx's Avatar
FormerVendor
2 Stroke Engine Oil should never be used as a lubricity replacement for Diesel Engines under any circumstances. 1.) 2 stroke engine oils are generally blended with up to 25% mineral spirits, thus causing a loss in BTU / HP. 2.) The additive chemistry formulated in 2 Stroke Engine Oil was not designed for the pressures in diesel fuel injection systems, especially in newer vehicles. 3.) The amount of Detergent (deposit control additive) is ten times stronger than that used in a fuel additives whether ours or some other leading additive companies. That being said, if your vehicle has any type of blow by, you run a good chance of poisoning your Catalytic Converter.
Old Jan 27, 2010 | 01:33 PM
DB Admin's Avatar
Banned
I copied your post over here about two stoke oil
Old Jan 27, 2010 | 01:35 PM
DB Admin's Avatar
Banned
Most of us Dont have Catalytic Converters , and some of us have resonators ,
other than that 2 stroke oil sounds like poison to our trucks ?
Old Jan 27, 2010 | 01:42 PM
blkjack's Avatar
Then what would be the best "additive" to put in our trucks to make up for the lack of lubricity that ULSD is lacking
Old Jan 27, 2010 | 01:44 PM
DB Admin's Avatar
Banned
Old Jan 27, 2010 | 01:45 PM
moneyman_09's Avatar
Well for us out there who run straight pipes and have no worry bout the epa is 2 stroke ok then? i've been using it for awhile in my older diesel mercedes and my cummins seams to quiet the motors alot
Old Jan 27, 2010 | 01:48 PM
DB Admin's Avatar
Banned
i moved your post here
Old Jan 27, 2010 | 01:54 PM
Fuel Dr Rx's Avatar
FormerVendor
Use a good reputable company that has been in business for years. You want to use a company that has a solid reputation in the additive business. I would stay away from companies, that promote their products through Truck Pulls, or Stadium Sponsorships. I would lean toward companies that supply fuel additives to the refinery or fuel suppliers themselves. This will give you the ease of mind that the product has been field tested and proven from refinery to end user. There are a lot of backyard start up companies with out the proven years of field experience trying to ride on reputable additive companies.
No, and the reason why about 2 Stroke Oils, you can still form deposits on top of the cylinder heads themselves and also around the piston rings which could eventually cause piston ring deposits. This would be a cause for cylinder wear, which then could lead to fuel blow by, which leads to Fuel Dilution in your crankcase and shortened oil drains.
Last edited by Fuel Dr Rx; Jan 27, 2010 at 01:54 PM. Reason: Automerged Doublepost
Old Jan 27, 2010 | 02:08 PM
K50's Avatar
K50
What causes cylinder deposits in the 2-stroke oil?
