Schaeffer Premium Diesel Visit - Schaeffer Premium Diesel
What are the dangers of low sulfur diesel fuel ?
Old Jan 27, 2010 | 12:19 PM
DB Admin's Avatar
Banned
Default What are the dangers of low sulfur diesel fuel ?
What are the dangers of low sulfur diesel fuel , and how can your product help ?
Is your product an emulsifier or a demulsifier ?
Old Jan 27, 2010 | 12:31 PM
Fuel Dr Rx's Avatar
FormerVendor
ULSD (Ultra Low Sulfur Diesel) is what they call a very dry fuel. Dry meaning, very low lubricity for your fuel pumps and injectors which can cause premature failure. Almost all of our products have a additional amount of synthetic lubricity additive (Synshield) formulated into them, depending on the product.
In regards to emulsifier or demulsifier? There are two schools of thought which is better... Early testing with ULSD should more potential problems with bacteria due to the lowered amount of sulfur in the fuel. Sulfur in itself is a natural Biocide, and due to the severe hydrotreating (Sulfur Removal Process in Refining) fuels lost their natural biocide. Schaeffer's uses a additive to absorb moisture in the fuel and to encapsulate it to burn out through the exhaust. The reason for this, if you eliminate moisture in your fuel / storage tank there is no food source presence to fuel bacteria growth.
Old Jan 27, 2010 | 12:40 PM
DB Admin's Avatar
Banned
Why doesnt anyone offer a bottle of sulfur to add to your tank ?
Old Jan 27, 2010 | 12:44 PM
ArizonaRedneck's Avatar
and for us that use two stroke oil what does your product offer that regular old two stroke dont
Old Jan 27, 2010 | 12:45 PM
12vcummins96's Avatar
x2
Old Jan 27, 2010 | 01:23 PM
Fuel Dr Rx's Avatar
FormerVendor
Due to epa compliance all additives used must below 15PPM of Sulfur. There is not liquid sulfur that is available. Also by using powdered sulfur and trying to liquifi it, would actually plug your fuel filter itself.
Old Jan 27, 2010 | 01:29 PM
tdiezel's Avatar
So what can we do to remedy the problem? We all love our trucks and want to keep them running. What products do you suggest we use? Should we be putting octane boosters or something of the like in our fuel to help our vehicles last longer?
Old Jan 27, 2010 | 01:31 PM
Fuel Dr Rx's Avatar
FormerVendor
2 Stroke Engine Oil should never be used as a lubricity replacement for Diesel Engines under any circumstances. 1.) 2 stroke engine oils are generally blended with up to 25% mineral spirits, thus causing a loss in BTU / HP. 2.) The additive chemistry formulated in 2 Stroke Engine Oil was not designed for the pressures in diesel fuel injection systems, especially in newer vehicles. 3.) The amount of Detergent (deposit control additive) is ten times stronger than that used in a fuel additives whether ours or some other leading additive companies. That being said, if your vehicle has any type of blow by, you run a good chance of poisoning your Catalytic Converter.
DB Admin's Avatar
Banned
i use the redline or powerservice but would like to try your product
Old Jan 27, 2010 | 01:33 PM
Deezel Stink3r's Avatar
Just as an Info:
german military uses official 2-stroke oil to add missing lubricity in Jet fuel which has far less lubing abilities than ULSD.
After 4 years of hard testing it is approved by order.
Interview between Gary Hirschlieb vice president Bosch USA and Joe Petitt:
