nozzels
Old Jan 26, 2010 | 06:45 PM
powerstroker52's Avatar
Default nozzels
hey im lookin for injector nozzels if any one has any info.....thanks
Old Jan 26, 2010 | 07:12 PM
NCFPD's Avatar
whats your alls opinion on the best 50hp injectors.
Hit up Luke for some he has good prices on them but you might be better off buying new injectors
Old Jan 26, 2010 | 07:13 PM
If you have a good shop close by that can set them up and pop test them for ya then get the nozzels. If not then I would get the full injectors.
Old Jan 26, 2010 | 07:28 PM
whats the deal with the pop test, the truck only has 60,000 miles im sure thier fine i just wanna upgrade and dont feel like buying the whole injector and nozzels are cheaper you know,.
whats the pop test?
Last edited by powerstroker52; Jan 26, 2010 at 07:28 PM. Reason: Automerged Doublepost
Old Jan 26, 2010 | 07:31 PM
NCFPD's Avatar
basicly when you take off the nozzle and put new onws on there certin shimms inside and alot of other stuf that must be set just right the pop test is a test that makes sure they spray just right and they pop open at the right psi I think im not totally sure bout all that but thats what i have herd
Old Jan 26, 2010 | 07:35 PM
so i take it these arnt as easy as my nozzels on my stroker, i rebuilt my stroker ionjectors more then once without and problems so are thesse tottaly differnt?
Old Jan 26, 2010 | 07:41 PM
turbo20psi's Avatar
Pop-testing is to make sure the injector opens at a certian psi between 1800 to 1950 psi.If the prussure is not equal on each injector there will be idle issures,dead cylinder problems.You are going to change that when you change the nozzels.
