HT3B Oil drain
Old Jan 26, 2010 | 03:48 PM
SteveinAz's Avatar
Default HT3B Oil drain
Ok, I'm mocking up my compound turbos. Where do I put the oil drain/return for the HT3B? I don't want to tee into the HX35w14 drain.
Also should I dump the HX35 wastegate into the 5" exhaust or leave it on what is going to become the intermediate hot pipe between the 2 turbos.
This setup is for towing, BTW
Old Jan 26, 2010 | 04:35 PM
93_Fummins's Avatar
Most setups I've seen braze in a drain into the oil pan itself.
As for the wastegate, leave it as it is, dumping into the "intermediate" hotpipe. You'll need the wastegated exhaust as well as the expelled exhaust from the from the HX35 to help push the HT3B. Just my opinion...
Old Jan 26, 2010 | 04:39 PM
RSWORDS's Avatar
Yep, Pull teh pan and put a drain in it. You can get it out with the engine in the truck.
Old Jan 26, 2010 | 04:40 PM
Diesel Dummy's Avatar
older engine will need a oil pan tapped, newer blocks have a rear drain cast in the block.
Old Jan 26, 2010 | 04:50 PM
SteveinAz's Avatar
I'm concerned with overspeed on the small turbo. Should I be?
Old Jan 26, 2010 | 08:06 PM
RSWORDS's Avatar
not with the waste gate.
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
rodbuilder
Jun 26, 2015 12:48 AM
coors_man_2005
Dec 15, 2014 10:23 AM
